Component: PWM (CAL) (Misc)
Version 2.2
Category Misc
PWM component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Pulse Width Modulation peripheral.
FREE
Fc9-comp-macro.png GetValue
Returns Named property Value
Fc9-string-icon.png - STRING Name
Fc9-comp-macro.png ChangePeriod
Change the Period (and prescaler) for this PWM Channel
Fc9-u16-icon.png - UINT period
period value PIC/AVR: 0-255 16-bit PIC: 0-65535
Fc9-u16-icon.png - UINT prescaler
prescaler 1,4,16,64
Fc9-comp-macro.png Disable
Disable this PWM Channel
Fc9-comp-macro.png SetDuty8Bit
Set the Duty cycle (0-255) for this PWM Channel
Fc9-u8-icon.png - BYTE duty
duty value 0 - 255
Fc9-comp-macro.png Enable
Enable this PWM Channel
Fc9-comp-macro.png ChangeFrequency
Advanced function for the ESP32 hardware to set the PWM output frequency.
Fc9-u32-icon.png - ULONG Frequency
New PWM desired frequency in Hz
Fc9-comp-macro.png SetValue
Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD)
Fc9-string-icon.png - STRING Value
Fc9-comp-macro.png SetDuty10Bit
Set the Duty Cycle for this PWM Channel. PIC/AVR - Range: 0-1023 16-bit PIC - Range: 0-65535
Fc9-u16-icon.png - UINT duty
Duty value 0 - 1023
Fc9-comp-macro.png SetDutyFloat
Advanced function for the ESP32 hardware to set the PWM duty as a percentage between 0.0 and 100.0
Fc9-f32-icon.png - FLOAT Duty
Fc9-comp-macro.png GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
Fc9-type-16-icon.png Channel
PWM Channel selector
Fc9-type-16-icon.png Alt Pin Enable
Alternative Pin Enable (if available on target device)
Fc9-type-5-icon.png Port
Fc9-type-14-icon.png Period Register
Allows the user to change the number of counts for the whole PWM period. Note that all PWM channels based on the same timer will share the same period overflow. PIC/AVR Range: 0 - 255 16-bit PIC Range: 0 - 65535
Fc9-type-16-icon.png Prescaler Divide
Allows the user to change the number of program cycles per PWM cycle count. Note that all PWM channels based on the same timer will share the same prescaler.
Fc9-type-16-icon.png PWM Timer
Timer associated with PWM to drive the output. Warning - All PWM channels linked to the same timer will share the same period and prescaler settings.
Fc9-type-14-icon.png Clock Speed
Fc9-type-15-icon.png Period (uS)
Fc9-type-15-icon.png Frequency (KHz)
Fc9-type-15-icon.png Frequency (Hz)
Fc9-type-14-icon.png Master Divider
