Component: Potentiometer (Black) ()
Version 1.4
Category
Potentiometer (Black) component
Potentiometer with black plastic knob. Pointer colour can be changed in component properties.
Note: The default Vref properties for AVR/Arduino is AREF. If there is no voltage being applied to the AREF pin, then you must change Vref option from AREF to AVCC
BASICIO
FC6 Icon.png Potentiometer Example
Fc9-conn-icon.png Simulation
Fc9-type-15-icon.png Start Angle
Fc9-type-15-icon.png Sweep Angle
Fc9-type-1-icon.png Color
Colour of the pointer.
Fc9-type-7-icon.png Retain Value
If yes is slected After saving your project, the ADC value will be retained when your project is reloaded.
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Settings
