Component: Potentiometer (EBM002) (EBM Modules)
Version | 1.1 |
Category | EBM Modules |
Potentiometer component
This board consists of a standard shaft rotary potentiometer that provides a linear voltage output ranging between the microcontroller power rails. This can be connected to an Analogue to Digital input of the microcontroller in order to provide a control value.
SENSORS
This example simply reads the value from the potentiometer sensor component and outputs the value to an LCD as a number in the range 0-255.
The ADC bit depth can be increased to 10 or 12 bit depending on your device by changing the Mode parameter to 1 in the ReadPotentiometer component macro.
ReadPotentiometer |
Macro to read the potentiometer Mode = 0 will return a byte Mode = 1 will return an int | |
Mode |
0 = return BYTE, 1 = return INT | |
Return |
