Component: Proximity Switch Template (Sensors)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | Sensors |
Proximity Switch Template component
Polls a chosen panel object to test it's distance from this component. When the test object is within the detection range, the state of a pin is changed, and a User event generated. Used for building models of reed swicthes and hall sensors.
SENSORS
Simple example showing the proximity detector component at work, when a proximity is detected the direction of the motor is reversed.
Detector
ReadState |
Get the current collision state. The 'Polarity' property will affect whether a collision is represented by a high or low state. | |
Return |
