Component: RGB Xmas Tree (Misc Circuit)
Author MatrixTSL
Category Misc Circuit
RGB Xmas Tree component
Component complete with macros and simultion to drive the MatrixTSL RGB Xmas Tree decoration.
FREE
For more information please refer to the Xmas Tree blog post.
Fc9-comp-macro.png PlayNote
Plays a specific note for the length of time specified.
Fc9-u8-icon.png - BYTE Note
0-59 - 0=C, 1=C#, 2=D, 3=Eb, 4=E, 5=F, 6=F#, 7=G, 8=G#, 9=A, 10=Bb, 11=B, 12=C...
Fc9-comp-macro.png WaitAudio
Checks to see if the audio circuit is current outputting a tone. If it is then the macro will wait until the audio is free again.
Fc9-u16-icon.png - UINT Delay
Optional ms delay after the audio has stopped playing 0=No Delay
Fc9-comp-macro.png SetColours
Generates a colour value based on the input colour parameters and asigns it to all of the LEDs.
Fc9-u8-icon.png - BYTE Red
Red 0=None, 255=Max
Fc9-u8-icon.png - BYTE Green
Green 0=None, 255=Max
Fc9-u8-icon.png - BYTE Blue
Blue 0=None, 255=Max
Fc9-comp-macro.png RandomLED
Randomises the colour to a specific LED
Fc9-u8-icon.png - BYTE LED
LED 0 to NumLEDs - 1
Fc9-comp-macro.png MoveToColour
Generates a colour value based on the input colour parameters and transitions one of the LEDs to the new colour. Remains in the function until the new colour has been reached.
Red 0=None, 255=Max
Fc9-u16-icon.png - UINT TransistionDelay
Delay in milliseconds between each transition
Fc9-comp-macro.png SetLED
Directly sets the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
Fc9-u8-icon.png - BYTE Colour
Fc9-comp-macro.png JingleBells
Plays the Jingle Bells tune using the audio driver.
Fc9-comp-macro.png SetLEDs
Sets the colour of all the LEDs. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
Fc9-comp-macro.png CheckSwitch
Checks to see if the switch is pressed. Returns 1 to indicate a press and 0 to indicate not pressed.
Generates a colour value based on the input colour parameters and asigns it to one of the LEDs.
Red 0=None, 255=Max
Fc9-comp-macro.png CheckAudio
Checks to see if the audio circuit is current outputting a tone. Returns 1 to indicate audio active and 0 to indicate not active.
Fc9-comp-macro.png RandomLEDs
Randomises the colour of all the LEDs
Fc9-comp-macro.png GetLED
Directly read the colour of a single LED. Red = 3-bit, Green = 3-bit, Blue = 2-bit 0bBBGGGRRR
Fc9-comp-macro.png Initialise
Starts up the LED PWM and Audio software driver.
Fc9-conn-icon.png Pin Connections
File:Fc9-type-19-icon.png LED Data Port
Fc9-type-5-icon.png LED Clock Pin
Fc9-type-5-icon.png LED Enable Pin
Fc9-type-5-icon.png Audio Output Pin
Fc9-type-5-icon.png Switch Input Pin
Fc9-conn-icon.png LED Properties
Fc9-type-21-icon.png Number Buffers
Number of octal buffer IC's you will require to drive the LEDs. Note that the microcontroller data port provides the first buffer so the numbr of ICs is actually one less than the value shown.
Fc9-type-21-icon.png Number LEDs
Fc9-type-7-icon.png Test On Startup
Performs a simple LED test routine on start up. LEDs should all light up white, red, green and blue in second intervals.
