Component: Range Time of Flight (VL53L0X) (Light)
Author MatrixTSL
Category Light
Range Time of Flight (VL53L0X) component
A laser based range sensor designed to provide accurate range infomation for a very narrow sensing beam. Capable of sensing ranges from 50mm to 1200mm. Communication with the device is based on a I2C bus.
FREE
Simple example showing the proximity detector component at work, when a proximity is detected the direction of the motor is reversed. FC6 Icon.png Detector
Fc9-comp-macro.png ReadModel
Collects the model number from the sensor
Fc9-comp-macro.png ReadRevision
Collects the revision number from the sensor
Fc9-comp-macro.png ReadDistance
Read the current distance in mm. Returns -1 if the sensor timed out during the read operation.
Fc9-s16-icon.png - INT Return
Fc9-comp-macro.png ReadRegister
A simple example showing a generic way to read a register using I2C.
Fc9-comp-macro.png WriteRegister
A simple example showing a generic way to write a register using I2C.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png I2C Properties
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulation
