Component: Robot Arm AllCode API (AllCode)
Version | 1.0 |
Category | AllCode |
Robot Arm AllCode API component
Matrix 5-axis Robot Arm with Gripper. Compatible with the Matrix Robot ARM Training Curriculum and Hardware. Features gripper pressure sensor, light sensor, colour sensor, Potentiometer, Magnetic sensor.
FREE
LEDOn |
Switches on a single LED, LA0-LA7 | |
Index |
0=LA0, 1=LA1, 2=LA2, 3=LA3, 4=LA4, 5=LA5, 6=LA6, 7=LA7 | |
Return |
LEDOff |
Switches off a single LED, LA0-LA7 | |
Index |
Return |
LEDWrite |
Allows a value to be sent to control all eight LEDs LA0-LA7 at once | |
Value |
(0-63) 0b000000 | |
Return |
GetAPIVersion |
Gets the API version of the Robot ARM Firmware | |
Return |
GripperOpen |
Fully opens the gripper at the end of the arm ready to pick something up. | |
Return |
KineSetXYZ |
Sets the XYZ position and calculates the various servo motor angles required. Returns 0=Impossible, 1=InPosition | |
X |
Y |
Z |
Return |
ReadSwitch |
Read the value of a single switch. Returns the value as a byte | |
index |
0=SA0, 1=SA1, 2=SA2, 3=SA3, 4=SA4, 5=SA5, 6=SA6, 7=SA7 | |
Return |
LCDPrintStr |
Breaks down a string of text and sends it to the LCD via the private RawSend(byte, mask) macro | |
PrintString |
Enter the text or variable to print to the LCD | |
Return |
ReadColourChannel |
Reads a single colour channel from the value returned from the ReadColour macro. | |
Index |
0=Red, 1=Green, 2=Blue | |
Colour |
Return |
Park |
Parks the Robot ARM and switches off the servo motors | |
Return |
StorePosition |
Stores the current position of the ARMs 5 axis. | |
Index |
Save Index - Range 0-29 | |
Return |
ReadPressure |
Read the value of the pressure sensor on the ARM gripper. Returns the value as a byte | |
Return |
GotoPosition |
Recalls a previously saved position for the ARMs 5 axis. | |
Index |
Return |
MotorsMoving |
Checks to see if any of the motors are still moving. | |
Return |
Beep |
Allows the beeper to output a warning | |
Iterations |
Number of times to repeat | |
OnDelay |
Delay in ms | |
OffDelay |
Delay in ms | |
Return |
SetTrim |
Allows minor adjustment on the 5 axis servo motors | |
Index |
Motor Index Range 0-4 | |
Trim |
Amount of Trim Range 0-255, Default Value 128 | |
Return |
KineGetXYZ |
Calculates the current XYZ position from the current servo position coordinates | |
Index |
Range 0-2 : 0=X, 1=Y, 2=Z | |
Return |
LCDVerbose |
Controls if the LCD is in user mode or verbose API mode, | |
Mode |
0=User Mode, 1=API Verbose Mode | |
Return |
LCDPrintNum |
Will allow you to print a number. This is limited to a signed-INT, -32768 to 32767 | |
Number |
Enter the number or variable to print to the LCD | |
Return |
LCDClear |
Clears the entire contents of the display. | |
Return |
Properties |
Connections |
Operating Mode |
Mode |
