Component: API (ECIO40P) (API Slave Devices)
Version 4.0
Category API Slave Devices
API (ECIO40P) component
Connects to an ECIO40P running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
FREE
The App Developer (ECIO40P) component allows an ECIO40P board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ECIO40P hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
ZIP Icon.png ECIO40P App Developer Firmware
The COM port to the ECIO hardware is selected via the SCADA_ECIO40P component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
Device Port Pin A0 A1 A2 A3 A4 A5 B0 B1 B2 B3 B4 B5 B6 B7 C0 C1 C2 C6 C7 D0 D1 D2 D3 D4 D5 D6 D7 E0 E1 E2
App Developer Slave Analogue Pin 0 1 2 3 4 5 6 7 8 9 10 11 12
Device Port Pin A0 A1 A2 A3 A5 E0 E1 E2 B2 B3 B1 B4 B0
App Developer Slave Peripheral Pin I2C SDA I2C SCL SPI MOSI SPI MISO SPI SCK UART RX UART TX PWM 0 PWM 1
Device Port Pin B0 B1 C7 B0 B1 C7 C6 C2 C1
Direct Slave Access
Here is a simple demo to switch on and off digital pin 29 (the LED pin).
FC6 Icon.png ECIO40P App Developer Example
Rapid Development - Virtualised SPI
A feature of the App Developer Slave interface is to use the component for rapid development.
The App Developer Slave hardware can be used to take communications from the Flowcode simulation and transfer them to a real world device allowing for easy code generation and test without having to download to a target microcontroller device.
The CS pin and SPI Prescaler are set via the properties of the Injector component.
The SPI Master component is linked to the Injector component via the Injector property.
The Injector component is linked to the App Developer Slave component via the App Developer Slave property.
FC6 Icon.png ECIO App Developer Slave SPI Demo
Rapid Development - Virtualised I2C
The I2C Master component is linked to the Injector component via the Injector property.
FC6 Icon.png ECIO App Developer Slave I2C Demo
Rapid Development - Virtualised UART
The Baud rate and optional RS485 Properties are set via the properties of the Injector component.
The UART component is linked to the Injector component via the Injector property.
FC6 Icon.png ECIO App Developer Slave UART Demo
Fc9-comp-macro.png I2CInitialise
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
Fc9-comp-macro.png ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0-5
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u8-icon.png - BYTE Samples
8-bit samples returned from the function
Fc9-comp-macro.png SPITransferTrans
Fc9-u16-icon.png - UINT Count
Outgoing data
Fc9-u8-icon.png - BYTE DataIn
Incoming data
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-29
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
Fc9-comp-macro.png ADCSample8
Reads the voltage present on an Alanog pin as an 8-bit value range 0-255
Range: 0-12
Fc9-comp-macro.png I2CTransReceive
Data variable to receive into
Number of bytes to receive
Fc9-comp-macro.png UARTInitialise
Fc9-comp-macro.png UARTCheckRX
Fc9-comp-macro.png RegisterWrite
Writes to one of the registers on-board the device
Fc9-u16-icon.png - UINT RegisterAddress
The address of the register
The data value to assign to the register
Fc9-comp-macro.png ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
Fc9-u8-icon.png - BYTE ChargeTime
Default 10
Fc9-comp-macro.png RegisterRead
Read one of the registers on-board the device
Fc9-comp-macro.png I2CRestart
Fc9-comp-macro.png PWMDisable
Disable a PWM output
Range: 0-1
Fc9-comp-macro.png I2CStart
Fc9-comp-macro.png I2CReceive
Fc9-bool-icon.png - BOOL Last
Fc9-comp-macro.png I2CStop
Fc9-comp-macro.png ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
Fc9-u8-icon.png - BYTE RefType
0=VDD 1= VREF+ (AN3)
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
Fc9-comp-macro.png PWMSetDuty
Range: 0-1
Fc9-u8-icon.png - BYTE Duty
Fc9-comp-macro.png ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
Range: 0-12
Fc9-comp-macro.png I2CTransSend
Data to send
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
Fc9-comp-macro.png IOSetOutputPin
Range: 0-29
Fc9-bool-icon.png - BOOL State
Range: 0-1
Fc9-comp-macro.png ADCSampleAverage10
Range: 0-5
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
Fc9-comp-macro.png SPIInitialise
Fc9-comp-macro.png I2CSend
Fc9-comp-macro.png UARTSend
Fc9-comp-macro.png PWMSetPrescaler
Fc9-u8-icon.png - BYTE Period
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-1
Fc9-comp-macro.png ADCSampleArray10
Range: 0-5
Range: 1- 32
Fc9-u16-icon.png - UINT Samples
Fc9-comp-macro.png ADCSampleAverage8
Range: 0-5
Range: 1- 100
Fc9-comp-macro.png Initialise
Initialise the comms to the ECIO40P device, ready for commands to be sent.
Fc9-conn-icon.png Connection
Fc9-type-7-icon.png Auto Detect
Fc9-type-16-icon.png COM Port
Lists all the current available COM port hardware on your PC.
Fc9-type-7-icon.png Refresh Ports
Fc9-conn-icon.png API Peripherals
Fc9-type-21-icon.png Digital IO
Fc9-type-21-icon.png Analog Input
Fc9-type-21-icon.png Analog Output
Fc9-type-21-icon.png PWM Output
Fc9-type-21-icon.png I2C Bus
Fc9-type-21-icon.png SPI Bus
Fc9-type-21-icon.png UART
Fc9-type-21-icon.png SERVO
Fc9-conn-icon.png Console
Fc9-type-7-icon.png Console Log
Create an automatic console log of the commands sent to the Arduino
Fc9-type-16-icon.png Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
