Component: SPI (CAL) (Misc)
Version 2.1
Category Misc
SPI component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. A low level implementation giving direct access to the Serial Peripheral Interface peripheral.
FREE
Fc9-comp-macro.png Master_Enable_CS
Outputs a low signal to the chip select pin to select the remote slave device.
Fc9-comp-macro.png Slave_Uninit
Uninitialise the Slave
Fc9-comp-macro.png Prv_TextConsole
Send text to the SPI console. Exposed as part of the CAL_SPI component to allow none AutoCS pins and other.
Fc9-string-icon.png - STRING str
Fc9-u8-icon.png - BYTE Colour
0=Default, 1=TX, 2=RX
Fc9-u8-icon.png - BYTE AppendTimestamp
0=Don't Append / 1=Do Append
Fc9-comp-macro.png Master_Transaction
Sends and receives data bytes via the SPI channel. The Buffer is to contain the data to be sent, and is overwritten by the retuning data from the device. Returns 1 for success, 0 for failure
Fc9-u8-icon.png - BYTE Buffer
Number of bytes to transfer
Fc9-comp-macro.png GetValue
Reads Named property Value.
Fc9-string-icon.png - STRING Name
Fc9-comp-macro.png Slave_Init
Initialise the Slave
Fc9-comp-macro.png Master_Disable_CS
Outputs a high signal to the chip select pin to deselect the remote slave device.
Fc9-comp-macro.png Master_Uninit
Uninitialise the Master
Fc9-comp-macro.png Master_Byte
Sends and receives a data byte
Returns a handle to the console used by this component
Fc9-comp-macro.png Slave_TxByte
Sets the data to be transmitted to the SPI master.
Fc9-comp-macro.png Slave_RxByte
Returns the data received from the SPI Master
Fc9-comp-macro.png SetValue
Change Named property to new Value.
Fc9-string-icon.png - STRING Value
Fc9-comp-macro.png SetPrescaler
Sets the prescaler value for the clock divider chain
Fc9-comp-macro.png Master_Init
Initialise the Master
Fc9-comp-macro.png GetList
returns Named property list
Fc9-type-7-icon.png Component Enable
A global flag to enable or disable the SPI component from producing code. Useful for generating components with multiple communications options.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-7-icon.png Use Auto CS
Allow the SPI component to manage the CS pin for us in Master mode. On initialise the CS pin is automatically set high to disable the remote SPI device. Set to No if you want to create a component with multiple CS pins or if you want to manage the CS pin yourself.
Fc9-type-5-icon.png CS / SS
Fc9-type-16-icon.png CS Polarity
Fc9-conn-icon.png Options
Fc9-type-16-icon.png Mode
Configures the mode of the SPI component. Currently only Master mode is supported.
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-16-icon.png Clock Phase
Fc9-type-16-icon.png Clock Polarity
Fc9-type-16-icon.png Sample Point
Data bit read sample point
Fc9-conn-icon.png Simulation
Fc9-type-16-icon.png API
Selects the API Slave to use to send and receive real world SPI data during simulation.
