Component: Switch (Push, Dashboard) ()
Version 1.1
Category
Switch (Push, Dashboard) component
Simple momentary push-button using the Matrix dashboard theme.
BASICIO
Here is an example Flowcode program to read the value of a switch. FC6 Icon.png Switch
(5V / 11K) * 10K = 4.54545V
Fc9-type-5-icon.png Connection
Chip pin to which the button is connected.
Fc9-type-16-icon.png Polarity
Whether the pin is taken high or low by pressing the button.
Fc9-type-14-icon.png Debounce (ms)
Time in milliseconds allowed for the pin to stabilise following a change of state. NB) Debouncing is only used when reading the switch state using the component macros. Chip pins are NOT debounced!
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Text
Text for the label displayed below the button.
Fc9-type-3-icon.png Font
Font to use for the text label beneath the buttion.
Fc9-type-1-icon.png Label Color
Color for the test of the label shown beneath the button.
Fc9-type-1-icon.png Bezel Color
Color for the bezel surrounding the button.
Fc9-type-1-icon.png Button Color
Color of the moving part of the button.
Fc9-type-16-icon.png Operation
Latching = Mouse click to turn on, click again to turn off. Momentary = Click to turn on, release to turn off.
