Component: Switch (Push, PCB, SMT) ()
Author | Matrix Ltd |
Version | 1.2 |
Category |
Switch (Push, PCB, SMT) component
Surface mount click switch, standard 6mm square size.
FREE
Switch
(5V / 11K) * 10K = 4.54545V
