Component: Thermistor Template (Sensors)
Jump to navigationJump to searchAuthor | Matrix |
Version | 1.0 |
Category | Sensors |
Thermistor Template component
Base component for creating thermistors. Has no GUI - this would be added by concrete examples using this basem which may or may not expose the propertes.
SENSORS
This example simply reads the value from the thermistor sensor component and outputs the value to an LCD as a temperature in degrees C.
EBM003 Example
GetIntegerTemperature |
Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
Return |
SetChannel |
Set the ADC Channel | |
ChannelID |
Return |
GetRealTemperature |
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
Return |
CalculateTemperature |
Converts the input ADC value and returns the Temperature in tenths of degree C | |
ADCValue |
ADC Reading to be converted | |
Return |
GetADCValue |
Returns the Raw ADC value from the Analogue Channel | |
Return |
