App Developer Examples
(Redirected from SCADA Examples)
Premade Examples
A set of premade example projects using App Developer can be found here.
https://flowcode.co.uk/app-developer/free-apps/
Template Examples
More example projects can be found by looking at the templates when creating a new App Developer project in Flowcode.
General Examples
Parametric graphs allows user to enter equations for X and Y, and then plot them. Which results in some very nice plots.
FC6 Icon.png Parametric Graphs
Simple drawing example using sliders to set the drawing pixel coordinate.
FC6 Icon.png Etchasketch
Example of Flowcode asking questions using UI dialogue boxes.
FC6 Icon.png Dialogue Boxes
Temperature forecasts for 3 user-entered locations in graph form.
FC6 Icon.png Temperature Forecasts
AllCode Examples
Formula AllCode
A simple example showing how to drive the Formula AllCode robot around in API mode using a panel based joystick control.
FC6 Icon.png Formula AllCode Bluetooth
The COM port for the Formula AllCode can be set via the panel properties which can be exposed to the SCADA runtime user.
MIAC AllCode
A simple example showing how to drive the MIAC AllCode PLC from a SCADA application using Bluetooth or WIFI.
FC6 Icon.png MIAC AllCode
Arduino Examples
Arduino Uno Custom Slave
A simple example demonstrating how to use an Arduino loaded with custom firmware with Flowcode SCADA.
Firstly we have an embedded project targetting an Arduino Uno that is connected to a bank of LEDs, a bank of switches and a temperature/humidity sensor.
FC6 Icon.png ArduinoUnoFW
Secondly we have a SCADA project that can interrogate and control the Arduino Uno allowing access to the switches, termperature and humidity while also allowing the LEDs to be controlled.
FC6 Icon.png ArduinoUnoSCADA
Internet Based Examples
MQTT
Local Weather
A simple example demonstrating how to use MQTT with Flowcode SCADA to get the local weather conditions.
The example shows temperatures from Halifax in the UK and from Sydney in Australia.
FC6 Icon.png SCADA BBC TEMPERATURES
Publish and Subscribe
A simple example to combine together an embedded device and a SCADA application.
Firstly we have an embedded Raspberry Pi project connected to an I2C Sensor, the sensor is sampled and the data is published to a MQTT server.
FC6 Icon.png RPI3 MQTT IOT EBM016
Next we subscribe to the data and receive it back into Flowcode SCADA.
FC6 Icon.png SCADA MQTT
Modbus TCP
A simple example demonstrating how to use the Modbus TCP components with Flowcode SCADA.
Here we have two Flowcoded SCADA projects communicting with each other. Though the master or slave could be replaced with embedded Modbus TCP hardware.
FC6 Icon.png Modbus TCP Master
FC6 Icon.png Modbus TCP Slave
Webserver Embedded Files
A simple example demonstrating how to host a website with fixed HTTP content including dynamic sections that can be passed in and out of Flowcode SCADA.
For example a dynamic section could be used to display a variable value on a webpage such as a temperature or used to control Flowcode e.g. turn on an output.
FC6 Icon.png Webserver Embedded
Webserver Dynamic Files
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of Flowcode SCADA.
FC6 Icon.png Webserver FileSystem
ZIP Icon.png Webserver Files
App to App Comms
A simple example demonstrating how to transfer data from one App Developer Application to another.
The example consists of a server and a client, the server sits and listens for incoming connections from clients and then services their requests.
The server pulls in any data sent to it and looks for a command start code ":" followed by a command body and terminated with a command end code ";\n".
Once it receives this it processes the command. The first byte sent after the command start is the command code and tells the server what the client is trying to do. This then provides the basis on what to do next, bytes to send and receive etc.
In the examples we have four commands A to D which are created in the ProcessCommand macro.
A takes a floating point value from the client and passes to the server.
B takes a floating point value from the server and passes to the client.
C takes a string value from the client and passes to the server.
D takes a string value from the server and passes to the client.
All four commands have an index allowing for a number of unique float and string values to be easily sent and received.
FC6 Icon.png App Developer AllCode API Server
FC6 Icon.png App Developer AllCode API Client
Generic Examples
Industrial Tanks
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
FC6 Icon.png Industrial Tanks
Key Mappings
A simple example showing the use of key mapping to switch three LED outputs on and off using the number keys 1, 2 and 3.
The keys are assigned via the Edit -> Key Mappings menu in Flowcode and continue to work after the SCADA project has been exported as a stand alone project.
FC6 Icon.png Key Mappings
