16F18877 & 16F15376
Darren.Smith
Flowcode V4 User
Has thanked: 2 times
Been thanked: 1 time
16F18877 & 16F15376
Post by Darren.Smith »
good morning, having a little trouble with programing these devices.
(24.92 KiB) Downloaded 408 times
when downloading to chip on eboo6 v9 it detects a 16f747 not the subject chips
Mloader is the same
(62.93 KiB) Downloaded 408 times
at the end of programing I get a little code protect error
(5 KiB) Downloaded 408 times
am I doing something silly or is there a problem with the mloader files?
cheers for any help.
Dazza
Darren.Smith
Flowcode V4 User
Re: 16F18877 & 16F15376
sorry forgot to mention I am using v8 of flowcode on windows 7 64bit system.
And Chip Config Settings are attached
(21.63 KiB) Downloaded 401 times
(21.86 KiB) Downloaded 401 times
(19.79 KiB) Downloaded 401 times
dazza
Hello Dazza,
I'm afraid the EB006 programmer does not have the firmware to allow it to program these newer devices. Microchip re-wrote the rules for programming with these newer devices. We added support for them in the new EB2 boards but currently the older EB1 boards do not have support.
If you have access to a PICkit 3 or 4 then you could program the chips using the ICSP header on the board.
Darren.Smith
Flowcode V4 User
thank you ben for your reply, this will be quite annoying for me im guessing. do all the old eb boards work with the new programmer with the connectors you sell? or do I have to buy all new boards to go with it?
dazza
Hi Dazza,
Yes old EB downstream boards should work fine with EB2 upstream using the adapters. Or a PICkit 3/4 may be a better way to go if you are happy with your current EB setup.
