Finding the correct Display shield
billduck
Has thanked: 23 times
Been thanked: 16 times
Post by billduck »
I routinely use an LCD display with 6 pushbuttons. This one <https://www.dfrobot.com/product-51.html>
I found the component macro, in an earlier version of Flowcode. It works fine. I use ver 8 now.
In the attached photo, I show the display, with properties, that works fine.
Also in the attached photo, I am not seeing an option for the display I am using on the pulldown.
If I show "enabled feature packs", from the help menu, displays are enabled.
Why can't I find the one I use?
Thanks in advanced.
Flowcode Dialog.jpg (82.5 KiB) Viewed 2915 times
viktor_au
Has thanked: 45 times
Been thanked: 63 times
Re: Finding the correct Display shield
Post by viktor_au »
Hello billduck
Did you try to use search?
billduck
Post by billduck »
Thank you so much. I found it. I was not aware of the search button. Seems like because of COVID-19, I am slowing down and learning some things.
It looks like you are missing some components in your menus there.
Do a full component update to get the complete menu lists.
Help -> Check For Updates.
See here for how to get all the latest files.
https://www.matrixtsl.com/wiki/index.ph ... _all_files
billduck
Post by billduck »
Updates are current. In fact, I really appreciate the update on Real Time Clocks the other day.
