PIC24FJ256GA406 UART Interrupt.(Solved)
seokgi
Has thanked: 18 times
Been thanked: 16 times
Post by seokgi »
Please help me.
I am using PIC24FJ256GA406 because I want to use six UARTs.
  UART 1,2,5,6 works fine with TX RX.
However, in UART 3 and 4, TX works well, but interrupt of RX does not work.
Please help me by referring to the program I made.
Thank you.
AD4325_24FJ256GA406-2.fcfx
(36.01 KiB) Downloaded 178 times
Re: PIC24FJ256GA406 UART Interrupt.
It seems odd that specific channels are not working. The code is fairly straightforward so it should either work or give compile errors.
One thing I noticed is that you are calling the same TX function from all of the RX interrupts which could potentially be problematic. It might be better to use a seperate circular buffer component for each RX interrupt and pop any incoming data into the buffer. Then in your main check all of the buffers for data and send this onto the TX function. This should get rid of any potential collisions.
seokgi
Re: PIC24FJ256GA406 UART 인터럽트.
Post by seokgi »
Hello!
I tested it in many ways, but it failed. The solution was solved by moving the RX pin to another pin. But I still don't know if it's a bad pin.
Thank you.
