Hi All
I am using the dsPIC33EP32MC204 with a external EEPROM 24C32.
The 24C32 works perfectaly when I use software mode, but I get no I2C when I use hardware mode channel 2 (SDA on B5 and SCL on B6).
Can anyone help with a fix?
Serial EEPROM 24C32
- Flowcode V4 User
- Has thanked: 29 times
- Been thanked: 30 times
- Has thanked: 182 times
- Been thanked: 179 times
Re: Serial EEPROM 24C32
Hi Lord Grezington
I guess this PIC has only 1channel which you can connect to either B4 B5 or B8 B9. If you have a few more I2C components on board, check which PIN they are connected to. Maybe you can switch these others to software, to try out whether the EEprom runs with I2C.
- Flowcode V4 User
Hi Stefan
I am fairly sure the dsPIC33EP32MC204 device does have two hardware I2C channels. I only need one channel (channel 2) using B5 & B6. I can not change these pins as the design is on a PCB.
The 24C32 works perfectly when I use software B5 and B6, but as soon as I switch to the hardware option there is no signals on either pin.
