Hello! Ben / Team
I would like to put to your notice one observation, while I try to create a new variable on the spot may be it is in the "Calculation Box", I write the new variable name and say okay, then FC prompts about the variable not available and then create a global variable, on saying yes a new window is automatically loaded for "Create a New Variable", this is very good and time saving, my concern was when the same thing is done with a "Decision" then the "Create a New Variable" window is not loaded, is it not possible to do the same with Decision too.
Thank you.
Abhi
Auto load "Create a New Variable" window
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: Auto load "Create a New Variable" window
Thanks for the suggestion, Abhi. I'm working on v9 at the moment and just added that functionality. We have no current plans to release an update to v8, but I will also add it to that code so it will be there if and when we do.
