Help with Variable comparison
electron67
Has thanked: 106 times
Been thanked: 48 times
Post by electron67 »
Hello, I thought it was an easy comparison, but comparing each variable with the others has been difficult and I got lost; I am trying to compare variables and know which is the one with the highest value; for example X1 = 25, X2 = 31, X3 = 45, X4 = 39, X5 = 40, X6 = 37, X7 = 29; how to find the correct data without so many comparisons between the variables.
Can someone help or guide me with this :?:
Enrique
mnf
Has thanked: 70 times
Been thanked: 440 times
Re: Help with Variable comparison
Post by mnf »
Hi Enrique,
Can you post your code so far?
The easiest way to do this would be to have the variables as an array (X[7]) then you can use a loop to find the highest (or lowest) value
electron67
This flowchart is what I think could be excluding variables until reaching the highest value, but I think it would be a huge program.
Enrique
COMPARACION.fcfx
(10.08 KiB) Downloaded 470 times
electron67
I am closer
electron67
I am closer
COMPARACION.fcfx
(8.95 KiB) Downloaded 472 times
mnf
Post by mnf »
Try something like this:
maxima.fcfx
(8.39 KiB) Downloaded 495 times
Note that I have added a C line in Maxima macro that allows this to macro to work with any size data array - however it will not simulate - so I've just used a fixed count (and added a comment on what to change for real-world use)
There are alternate ways to do this - for example if measuring some data then keep a record of highest value received.
Note - toUpper$ convert a string to upper case.
electron67
Hello Martin,
Excellent !!! It works, the program is simple, I would never have done it using that method. . .
Thank You !!!
Enrique
mnf
Post by mnf »
Glad to hear you got things working....
