Hello again,
I'm testing the evaluation version of Flowcode 8, and I'm trying to use the "Simulation Slide Switch" component.
But when I run the simulation, the slide doesn't move much when I click on it.
it will move about 1 or 2 pixels, but not enough to cover the "red" part of the "off" state, so, when I call the GetState macro I get the "on" state but visually it seems to be in the "off" state.
I tried to resize the component but it still have the same behavior.
Simulation Slide Switch Visual Bug
Re: Simulation Slide Switch Visual Bug
I beleive this may already have been fixed. Please try clicking Help -> Check for updates. Change the files in use drop down to full database and that should get you all the latest fixes and changes.
Let us know how you get on and if this solves the problem for you.
Thanks for letting us know. Should be fixed for you now.
