MCP4261 Digital Pot
Lord Grezington
Flowcode V4 User
Has thanked: 29 times
Been thanked: 30 times
MCP4261 Digital Pot
Post by Lord Grezington »
Hi All
We are trying to use the MCP4261 in a design, however when we add the component the parameters try to re-map to different pins as default. We dont need to re-map the pins and want to use the default pinout (MOSI D4, MISO D5 and CLK D6). There are no options to select these pins, even if we attempt using software mode.
We are using the 18F85K22
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: MCP4261 Digital Pot
Post by LeighM »
As a temporary workaround, in software mode, try the "MOSI" property, rather than the "MOSI Remap Pin" property
Lord Grezington
Flowcode V4 User
Hi Leigh
The probelm is we cant disable the re-mapping of the pins. On the software mode re-mapping is always on, and the pins available for the remapping are not the standard hardware pins.
LeighM
Post by LeighM »
Yes, I am not sure why the remap pins remain visible, looks like a bug.
Please just ignore them, and either use software, or Channel 1 for pins on port C, or Channel 2 for the pins on port D that you require.
