Hi All
Does anyone perhaps know why I can't compile any PIC projects?, I keep getting this error message below, any help would be greatly appreciated
Target folder: C:\Users\gavo\OneDrive\DOCUME~1\FLOWCO~1
Source name: C:\Users\gavo\OneDrive\Documents\Flowcode - Clicker 2\18F8722.fcfx
Title:
Description:
Device: PIC.18F.18F8722
Generated by: Flowcode v8.2.2.15
Date: Friday, August 21, 2020 20:22:22
Users: 1
Registered to: gavo
License key: R1W610
https://www.matrixtsl.com
Launching the compiler...
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat 18F8722 "C:\Users\gavo\OneDrive\DOCUME~1\FLOWCO~1\" "18F8722"
C:\Users\gavo\OneDrive\DOCUME~1\FLOWCO~1>"C:\Program Files (x86)\Microchip\xc8\v2.00\bin\xc8-cc.exe" -mcpu=18F8722 "18F8722.c" -w=359,1273,1388 -fshort-float -fshort-double -std=c90 -Os
The system cannot find the path specified.
Error returned from [xc8.exe]
C:\Program Files (x86)\Flowcode\Common\Compilers\pic\batch\pic_xc8_comp.bat reported error code 1
Autoclose turned off
FINISHED
PIC Compiling issue
Re: PIC Compiling issue
It look like from
Can you double check on your PC the actual location of and adjust the compiler path within edited batch file accordingly.
Looks like you have manually changed the path of the default compiler.
xc8-cc.exe
Thanks for the reply, somehow I don't have xc8-cc.exe is completely missing, is there something I can install?
- Has thanked: 553 times
- Been thanked: 1081 times
Apart from Flowcode itself you need to install the compiler package(s) for the target controller(s). You seem to be missing the PIC 8 bit compiler.
If you login to the Matrix website you can choose to download Flowcode. Just below the Flowcode download there is a ‘line’ Download Toolchains. You need to download and install ‘8bit PIC Toolchain’.
― C.S. Lewis
― C.S. Lewis
