64Bit Variables
Docara
Has thanked: 28 times
Been thanked: 61 times
64Bit Variables
Post by Docara »
Hello everyone,
Just noticed FC doesn't support long long variables (64bit) how can this variable type be implemented and used if FC?
Could I drop down to a C box and declare a long long then use it within FC as per normal?
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: 64Bit Variables
Post by kersing »
1. Please do not start a topic in Tips and Tricks for questions. Share your knowledge over there.
2. Flowcode does not implement 64 bit variables by itself. You might be able to use them in C code, depending on:
3. It helps if you specify which version of Flowcode you are using and what target chip you want to use. The different target families use different compilers with different capabilities.
― C.S. Lewis
