Interupt Question
anzacinexile
Has thanked: 16 times
Been thanked: 18 times
Interupt Question
Post by anzacinexile »
Hopefully a simple question being asked by a novice.
If a PIC is halfway through transmitting (or receiving) a RS232 string and an interrupt occurs, does the PIC respond immediately to the interrupt (and corrupts the RS232 string) or will it complete the RS232 task before responding to the interrupt?
Many thanks
Chris
Bachman
Has thanked: 9 times
Been thanked: 53 times
Re: Interupt Question
Post by Bachman »
The RS232 (UART) module is a dedicated module, controlled by the CPU. The CPU "tells" to the UART module to send a character and continues executing the program. The CPU can handle the interrupt during UART data transfer while the UART module is still transmitting or receiving the data. Same results with other peripherials. Here is the block diagram of a relatively simple µC, PIC12F1840:
Edit:
Not all pheriperials shown on this picture, mistake in the datasheet.
Hi Chris,
I agree with Bachman as long as the interrupt macro is fairly short lived. i.e. no delays or large amounts of code.
Unless your using a software UART and then all bet are off. Software UARTs should be last resort only and only used if/when you don't have any active interrupts.
anzacinexile
Cheers guys, much appreciated
Chris
