EB005- LCD and assembly
jgriffin
Post by jgriffin »
Guys,
I am attempting to display a character on the LCD using assembly language. The program use the following initialization codes:
0x33
0x32
0x2c
0x06
0x0c
0x01
0x02
This appears to work and I get a flashing cursor at postion zero.
The following code is use to send a "H" to the display.
;**** Data 'A'(48)
;****MSB
movlw 14 ; MSB first
movwf PORTB
movlw 34
movwf PORTB ; Pulse E high
movlw 14
movwf PORTB ; then low
call Sdelay
;****LSB
movlw 18 ; LSB second
movwf PORTB
movlw 38
movwf PORTB
movlw 18
movwf PORTB
call Sdelay
The "H" is not displayed and the cursor remains a position zero.
If you have a quick answer, I would appreciate it. If there is a reference I can read, let me know and I will use it.
Thanks,
Jack Griffin
Sean
Has thanked: 6 times
Been thanked: 44 times
Re: EB005- LCD and assembly
Post by Sean »
Timing is one of the main issues when communicating with the LCD. Setting and clearing microcontroller outputs within a few assembler instructions of each other may result in signals that are too quick to be received correctly by the display.
I would recommend a call to a delay subroutine before any change of state on the LCD pins. Some of the delays need to be several milliseconds.
A good data sheet on the Hitachi HD44780 will contain all the necessary command and timing information.
This site seems to offer a complete introduction to PIC/LCD interfacing using 8-bit mode. It should be possible to modify the code to 4-bit mode.
http://home.iae.nl/users/pouweha/lcd/lcd2.shtml
croudyj
Post by croudyj »
After initialization and before you send the H, you need a delay of at least 1.55ms. The Clear Display and Home commands take a longer time to execute than any of the others which need around 40us.
John
