I2C master slave help please
Pharaoh1989
Post by Pharaoh1989 »
hello, can anyone help me please, I have 3 pics set up and i am wanting to send and receive data, the master is a pic16f877a and the two slaves are pic16f886, I have attached the programs for you to look at, I cant seem to get it working correctly, any help would be very much appreciated.
thank you
I2C Slave 886 send and receive.fcfx
(13.48 KiB) Downloaded 130 times
I2C Master test 877A send and receive.fcfx
(17.48 KiB) Downloaded 153 times
Re: I2C
Hi Pharaoh1989,
I posted a project here which works with DS1307 and Ds3231 RTC.
Perhaps you can compare with the datasheet?
Note: Images missing due to a server issue.
Pharaoh1989
Re: I2C
Hi medelec35
thank you for your reply, ill have a look see if I can follow it.
cheers
Bachman
Has thanked: 9 times
Been thanked: 53 times
Re: I2C
Post by Bachman »
What is your I2C slave device? Be careful, different devices most of the times needs different type/sequence of commands.
