I have viewed a example to quad encoder counting number.so i modified it to show decimal number with encoder.but problem is its show int number insted of decimal number
i have attached the project.where was the problem in code?
Quad encoder help
Re: Quad encoder help
Hi, pollob00.
Instead of
Try instead
Without the preceding Float, then the float changed to an interger before being displayed on LCD.
If you are still having an issue, then precede Count: with the FLOAT key word:
If you want to display the float to 2 decimal places for example you can use
Instead of
dis = ToString$ (rty)
dis = FloatToString$ (rty)
rty = Count
rty = FLOAT Count
dis = FloatToString$ (rty,2)
Can you attached your modified flowchart and I will take a look at it, and see if I can spot the issue?
