hi all,
this is the first time i use flowcode 8 and i am trying to interface an HMI to arduino mega using modbus protocol, but
i don't understand how to do it, can someone help me?
thanks for your help
here the link for the hmi
http://www.we-con.com.cn/en/productsinfo_3964.html
best regards
arduino/hmi modbus
Re: arduino/hmi modbus
hi Abhi,
I don't have the hmi datasheet, but in the software it's possible to set the protocol type (master slave ect)
thanks!
thanks!
- Has thanked: 187 times
- Been thanked: 205 times
Without an available datasheet you might struggle. Perhaps you might find some assistance in the WiKi pages which give examples of using ModBus etc?
This is just one example
https://www.matrixtsl.com/wiki/index.ph ... s:_System)
hi,
sure, i just wanted to know if anyone has ever used a wecon display with arduino using flowcode, it is not clear to me how to write on the hmi
and read from it, i have not found examples.
Do i have to put both modbus master and slave in flowcode?
thanks for the help
thanks for the help
- Has thanked: 45 times
- Been thanked: 63 times
Flowcode team have SCADA system for industrial applications.
https://www.matrixtsl.com/wiki/index.ph ... trix_SCADA
https://www.matrixtsl.com/wiki/index.ph ... A_Examples
A simple example showing the hoppers, valves and pipes working together. Each tank automatically empties in turn.
I think you have to buy a SCADA component.
