Hi dear friends, Iam trying to code a program where I define a interrupt timer of 3ms, sampling a analog input reading and send through Uart. In simulation using flowcode the code works perfect and the variables change greatly. But when I Upload into the BL0032, the results look different in hardware compared to simulation. If somebody could help in any hint to solve this problem that would be great.
Rod
Analog_Pot_Uart
Analog_Pot_Uart
- PROG_Test_Analog_Pot_Uart.fcfx
- (16.76 KiB) Downloaded 187 times
- Analog_Output_Pot.jpg (85.25 KiB) Viewed 3897 times
Re: Analog_Pot_Uart
Hi.
I had a look at your flowchart.
The interrupt component must be called only once, so it's best to place it before the main loop.
That is probably the issue of why you are just getting 0?
I would not recommend placing the Modulus function within an interrupt.
It better to use
It better to use
interrupt_cntrl = interrupt_cntrl + 1
If interrupt_cntrl = 300 then interrupt_cntrl = 0: seconds_counter = seconds_counter + 1Martin
Re: Analog_Pot_Uart
Hi Martin thanks for replying. I corrected the place for the interrupt icon and it solved the problem about displaying values timer string. The problem now is that, the values for time string dont match what show on the simulation. I uploaded the the uart values, the analog is working but the timer should show an increment of 3,3ms for each sampling. Do you have any hints?
Thanks I appreciate
Rod
Thanks I appreciate
Rod
- Uart_Values_Display.jpg (100.18 KiB) Viewed 3845 times
Re: Analog_Pot_Uart
Hi Martin, I kept the same code for interrupt macro(The modulus) you've mentioned. Where do you insert that code you wrote? In a c code or the calculation flowchart? I tried to modified the code by not using the modulus, but the results in simulations were not what I wanted because it does not increment one of the variables that gives info about when it reaches 1 sec. If you run my code in simulation you'll see the increment from 3.3ms so on and when it reaches 1s you may see the variable incrementing to 1, which is one of the things I want to.
Rod
Rod
Re: Analog_Pot_Uart
Hi Rod,
For your flowchart to do what you want, It looks like the modulus is the way to go since you have not got any other modulus functions in your flowchart, except for the timer interrupt.
If you did have modulus functions in other user macros, including main, then to avoid corruption, an alternative would be to use: Which is the modulus equivalent.
I the value used is a power of 2 rather than 300, then bit-shifting would make it more efficient.
So, with your flowchart, if the timer interrupt is moved to above the main loop, it should hopefully work the way it's intended to?
