I have a SK6812 RGBW LED strip 5M and 300 LEDs.
I want to use this strip with two PIR sensors and must only work when it gets darker.
Does anyone has a working .fcfx file for this LED strip ?
Thanks,
Frank
- Has thanked: 187 times
- Been thanked: 205 times
Re: SK6812 RGBW LED strip 5M and 300 LEDs
I haven't personally used the strip, but as FC has components for all aspects of your project you should be able to achieve it.
Component Libraries > Outputs has the SK6812 listed
Component Libraries > Sensors has PIR and Light Sensors listed
You probably will want to set the strip to 1D with 300 LEDs.
HTH
HTH
I haven't used these before but I can probably knock up an example later. Whether it works or not is a different story...
I don't know if this will work in Hardware but it works in simulation.
In the attached example, the SK6812 component has been set to 1D with a total of ten LEDs in the string. You can easily change this to suit.
The chart can then be broken down into three parts after we initialise the component.
White Loop
This flashes all LEDs on and off three times
Red Loop
Does the same except the colour is Red
Blue Run
"Runs" a blue LED from beginning of the string to the end using a counter.
You could of course set any of the RGBW values to whatever you wish (0 minimum / 255 Maximum) and you can create whatever colour you want using the appropriate RGB combination.
When you make any change, for example set LED number 5 to whatever, nothing actually happens to the LED string. Changes are made in RAM and only then "clocked" out when you issue a Refresh Command (you could perhaps think on this command as "Apply").
This is just a very basic example but hopefully will show you how to control the string. I have used a PIC but the good thing about FC is that the code will pretty much be the same irrespective of target, just select whatever you want under Project Options.
Do note though that smaller chips won't be too suitable as a controller due limited RAM.
Hope this helps.
White Loop
Red Loop
Blue Run
Hope this helps.
- Example.fcfx
- (12.22 KiB) Downloaded 341 times
It should work with most chips as long as they have a decent amount of RAM available. For 300 leds I'm guessing you will want at least 1.5K as the leds will probably need around 1.2K. The chip I used in the example has 1K so will probably only work with up to 200 or so.
Let us know how you get on.
