Hi all,
I started with the Flowcode V7 30 day trial some time last month and was very satisfied with it, so I purchased a license for it. My account online does reflect that the license has been successfully added to my account, and am able to view its details. Once the 30 days were consumed, I tried to activate the license in flowcode but received the following:
Activation failed
Please contact technical support.
Error code V0W000007e5Nv
When I try clicking on Manual Activation, the icon at the top left is GREEN, and says, "This copy of Flowcode is activated to: License version: Standard version. 1 users can use Flowcode on the same network. You are licensed to use Flowcode for personal use only." As if the license has already been activated. Yet whenever I launch Flowcode, I am still prompted to either use the limited Free version, the 30 Day Trial (which I can't anymore), or Activate my license (which I can't).
When I went to my online account to try and download the license for manual activation, after I click "GET LICENSE", there is no text in the Activation Key field, other than:
=====Start key=====
=====End key=====
When I try to download the .key file, the webpage is stuck loading, or I get an Error 504 Gateway Time-Out.
I have also added Flowcode as an exception to my firewall, but that has not helped.
Any and all prompt help is greatly appreciated.
Sam
Activation Error Code: V0W000007e5Nv
Re: Activation Error Code: V0W000007e5Nv
Hi EtsDriver,
Sadly when I try to compose a message, I get this: "We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more in discussions to be able to use this feature."
Sam
Sam
EtsDriver
- Has thanked: 345 times
- Been thanked: 227 times
Hi! It might be because of your low post count, it should clear after couple posts. What version of Flowcode are you running? 7.xx?
Hello . I have the same problem when activating the license. do you know how it can be solved?
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Hi there,
Can you please send an email to the contact form here:
https://www.flowcode.co.uk/contact/technical/
Stating your username and any other information such as your Flwocode key.
Thanks!
Thanks!
