I would like to ask if when I create a new macro and then set the parameters and local variables and after that I have closed the window; I decide to edit/change the parameters of the macro, can I do that? Or I have to create a new one?
Thank you,
Best regards.
Macro editing
Re: Macro editing
No you can change the parameters of macros at any time. It is only when compiling that the C code is generated from the macros so at any other point the macros are free to be changed.
Re: Macro editing
In this case you would bring the macro to the front that you wish to edit and then click on the Macro Menu at the top and select Edit Details.
