I am unable to load a value of FF into the W reg (ie movlw H'FF'). When I try to do this W shows 7F. If I increment the W I can get it to contain FF but not load it. Is this a bug? Is there a fix?
Any help would be appreciated. Thanks
VLAB v2.0 Bug?
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: VLAB v2.0 Bug?
This seems strange. I've just created a program tthat simply has the instruction "MOVLW FF" and this works in the VPIC as expected. Can you please provide us with some more details of the problem, perhaps with a screenshot.
econnections
Re: VLAB v2.0 Bug?
Thanks for reply. This evening I will produce screen shots showing VLAB activity for your assistance. I assume you are using the same version?
Re: VLAB v2.0 Bug?
Seems to be some inconsistency here...
When you say VLAB do you mean VPIC?
Which software CD and version are you using?
econnections
Re: VLAB v2.0 Bug?
The link below shows the VLAB button in the ASM for PICmicro opening the Virtual PICmicro MCU. I treated the VLAB and Virtual PIC (VPIC) as two names discribing the same tool (simulator). As a beginner to assembly programming and ASM for PICmicro the between the two names is not made clear in the tutorials.
http://www.global-office.co.uk/pic/index.htm
Figures 3 & 4 show the register W being loaded with 0xFF and the binary equivalent using the movlw instruction. When the instruction is executed the value 0x7F appears in W and the ALU which is not what was intended.
I can't work out what is going wrong so I hope you can help.
If the program is allowed to loop then W will eventually overflow FF > 00
- Steve
Re: VLAB v2.0 Bug?
This is so strange. I've just rewritten your program and it works fine on my vPIC here. Can you try it on a different PC and see if the problem is the same?
If you tell me the details of your operating system (OS + 32/64-bit), I'll try to replicat e this issue on a similar PC.
We updated Assembly for PICmicros back in August and this has a new version of the vPIC, and perhaps this one would work better.
econnections
Re: VLAB v2.0 Bug?
I have been running to software on Windows XP Media Centre Edition Version 2002 SP2. The machine is an Acer Aspire T180, AMD Athlon 64x2 Dual Core Processor 3800+ 2GHz, 768RAM.
This morning I copied the VPIC directory to my w2000 server SP4 and run the same test programs - the problem was still there. I think it must be a bug in VPIC.
I had previously sent an email to Ben. If you wish you can send the update to that address?
econnections
Re: VLAB v2.1 Resolved Bug
Ben,
I installed version v2.1 and it allowed me to load the w register with FF. I then went back to v2.0 and it displayed 7E after loading w with FF. Clearly, there is a fault with the older version. It might be useful to setup an area in the forum for know bugs in both hardware and software so people can check for problems. I wasted many hours trying to get my program to work which turned out to be a fault in the software.
Now we only need to determine why INCFSZ and DECFSZ won't work when the 16F84A is set to XT.
Thanks for the update.
