Is it possible to use existing C-modules as macros? We have a set of modules (for example motor_speed(left,right)) and want to program a mobile robot with Flowcode using this modules.
Thanks...
Wijnand Nijs
Lecturer Digital System Desing
Fontys, the Netherlands
Existing C-modules as macros
Re: Existing C-modules as macros
Yes this is possible. Are your current C functions written using BoostC? If not then you may have to port the code across from your compiler into BoostC.
Then if you look inside the Flowcode V3/Examples folder at example TUT_33 then you will see that this uses external C functions. You should then be able to copy the example and get your own C macros working.
Let us know if you have any problems.
Thanks for your help, but I am using AVR controllers. Works it the same way for avr-gcc?
Thanks and greetings...
Wijnand Nijs
Wijnand Nijs
