CAN Adressing
PINTO
Flowcode v5 User
Been thanked: 1 time
CAN Adressing
Post by PINTO »
Hi Benj,
How can I adress the nodes on a can bus network via DIP Switches and still be able to use the CAN Component?
When is the Flowcode 4 going to be availabe?
Pinto
Dan81
Been thanked: 60 times
Re: CAN Adressing
Post by Dan81 »
Hello Pinto
CAN adress is 11 or 29 bit long.
You can read some (3 or more) bits of the RA port (for instance or the MCP2515 port) and choose among 8 (or more) fixed adresses.
Or you can create an adress with the upper bits fixed and lower bits according your DIP switches.
Then use the CAN Macro "SetTX..ID"
Daniel
can_switch.fcf
not tested
(8 KiB) Downloaded 407 times
PINTO
Flowcode v5 User
Re: CAN Adressing
Post by PINTO »
Hi Daniel,
Thanks for your input. I havn't had a chance to test it yet because I can't get the Canbus Component to work properly.
If i create a small program switching LED's On & Off on PortA 0,1,2,3 and PortA4,5 I have two inputs connected to a pic16f876 and 20Khz Xtal the program works when dowloaded to the PIC. But as soon I add Can Init. Icon the the PIC stops responding completelly.
I'm a bit stuck because I'm not sure if there's somthing wrong with the Canbus component or ther's something else to be set on the pic registers?
On the attached program the LED flases on Flowcode simulation but as soon is downloaded to the pic nothing works.
Any suggestions
Pinto Ramos
CANbusA book.fcf
(9 KiB) Downloaded 399 times
Re: CAN Adressing
What are your jumper settings on the CAN E-Block. You should have the jumpers in positions A and 1. Also make sure you are wiring 5V power to the E-Block board via the +V screw terminals.
PINTO
Flowcode v5 User
Re: CAN Adressing
Post by PINTO »
Hi Benj,
Thanks for the infio.
My connections seem to be ok.
I've connetect CS to RC0 INT to RC1 and changed the configuration bits on the Can module as well.
If you look at the attached program the LED on Port A1 should flash regardless if the Can is comunicating or not but it doesn't, if I remove all the CAN components from the flow chart and reload the code again than the LED Flashes, as soon as I add one of the can components the led's stop working again.
I'm using a pic16f876 with 20Mhz xtal (Not a 19.????) and My IO port is port A.
Pinto
CANbusA book.fcf
(8.5 KiB) Downloaded 357 times
Re: CAN Adressing
Hello Pinto
I cant see a problem with your program except that you are missing the initialise function at the top. Maybe you could add a LED flash after the Init function to make sure that it is completeing correctly before entering your while 1 loop.
Also for your incoming decision instead of using "RetVal <> 0" you can simply use "RetVal" and this will trigger if RetVal is any value other then 0.
Does this mean you have configured the patch system on the CAN E-Block to jumper setting 2 and wired connections from pin 0 to /CS and pin 1 to /INT?
There shouldn't be a problem with running at 20MHz or with the device you are using.
Let me know how you get on and I will have a dig in if it is still refusing to work correctly.
PINTO
Flowcode v5 User
Re: CAN Adressing
Post by PINTO »
Hi Benj,
I've tried what you suggested it didn't fix the problem.
I've placed a LED just after the init. Makro and the pic appear to be stuck on the initialazation makro.
I've re-installed Flowcode with a fresh copy made no difference.
I've simulated the code on Proteus as well and the same thing happen. I've noticed some acticity on the SPI pins and the PIC appears to be in some sort of a loop and not being able to get out of it.
You help is appreciated.
Pinto
Re: CAN Adressing
Hello Pinto
I have had a look into the problem and been able to replicate it here using the 16F876 and the 16F876A. I will see if I can find a way around the problem.
I have tracked the problem down to a single line of code in the initialise function at the moment.
//Put the CAN device into config mode
CAN_Config(REQOP_CONFIG);
PINTO
Flowcode v5 User
Re: CAN Adressing
Post by PINTO »
Hi Benj,
I've tried the same code on the pic16f877 and I got the same problem.
When could we expect the fix for the componet?
Pinto
Re: CAN Adressing
Hello Pinto
Ok I tracked the problem down to a hardware fault. Here is my setup for either a 16F876 or a 16F877.
CAN properties.
INT - 0
CS - 6
CAN E-Block jumper settings
A and 1 connected horizontally.
Multiprogrammer +V wired into +V on the CAN E-Block.
The problem on my test board was related to a faulty crystal. This was because I was using the development version of the board. I replaced my test board with a stock item and the CAN programs are now running correctly. If your board is less then a year old then you can send to me and I will check it and repare or replace if needed. Otherwise you can probably assume that it is the MCP2515 device that has somehow become damaged and simply try replacing this chip.
PINTO
Flowcode v5 User
Re: CAN Adressing
Post by PINTO »
Ok, now you got me even more confused.
Why is that the PIC gets stuck on the initialization?
Does the pic expect any kind of confirmation from the MCP2551 in order to go to the next step?
If that's the case, it makes sense the program freezes, meaning that the MCP2551 or the SPI section of the PIC are blown.
I'm going out now and buy some MCP2551's and replace them and try again.
Pinto
PINTO
Flowcode v5 User
Re: CAN Adressing
Post by PINTO »
Sorry I mean MCP2515 not MCP2551
Could you tell me as well on the configuration setup for the component the mumber for CS and INT mean connect to Port C0 and C6 on the actual pic and if so how do they change for the 18 pin Pics that this pins are on PortB
If I had to use any other pin on PortC for CS anf INT how would I configure them on flowcode?
Pinto
PINTO
Flowcode v5 User
Re: CAN Adressing
Post by PINTO »
Ok. The problem was....... I was using a 4Mhz Chip with the 19.660800Mhz :oops: Sorry.
I've now manage to get the PIC to initialize the CAN Bus module.
I wasn't yet able to get any sort of defenitive communications between the modules.
I searched the web and find out that one way of quick testing if the CAN Bus is electically healthy is to measure the voltage between the Hi and LOW lines and should be 2.5Vdc on standby and if the BUS communicates than HI wil go 3.75Vdc and LOW Line wil be 1.25Vdc refered to ground. This is happning but i didn't get any response from any of the nodes yet.
I will post if need any further help
Thaks for your help.
Looking forward for Flowcode4??
Pinto
Pinto
PINTO
Flowcode v5 User
Re: CAN Component setup
Post by PINTO »
How do I edit the values in the CAN component Box.
The component doesn't allow me to erase all the digits.
If I want to change the message ID I can't just erase all the numbers and enter a new one without having to fiddle with the cursor in the box. I'm sure this is not the way of changing the values?
Pinto
Re: CAN Adressing
Hello Pinto
Thats strange. If you untick the show values as hex tick box then does the same problem happen?
You may want to simply use the setTxID macro to assign the ID to the transmit buffer. This way you do not have to touch the transmit buffer properties.
PINTO
Flowcode v5 User
Re: CAN Adressing
Post by PINTO »
I'm not sure what you mean by "If you untick the show values as hex tick box"I don't have this feature in my version of the CAN component?? What I have is "Use Hex Notation box"
and no matter what I do to it as soon as I erase all the digits from any of the boxes to re-type the new value a window pops up (Invalid Value. Please enter a number between 0 and 2047, or between 0x0 and 0xFF if using Hex.)
I've now managed to get my project going. The project was to control 8 sets of traffic lights on a very un-usual roads crossing on a coal mine underground.
Some of the Traffic lights were as far as 300 meters away from the other lights and the very complicated operations logic made the all thing very challenging.
The other feature was because the units were spread to considerable distances the amount of cabling used was reduced to on 4*1.5mm cable (2 cores for 24Vdc and other 2 cores for CAN HI and CAN LO).
I still have a couple issues to resolve but for now the system is working great.
Thanks for your help.
Pinto
