LCD code
echase
Has thanked: 49 times
LCD code
Post by echase »
Looking at various versions of my compiled code I see that the C for the LCD contain these lines:-
void FCD_LCDDisplay0_GetDefines()
} //Dummy end of function to allow defines to be added correctly
//component connections
#define LCD_4129482_PORT portb
In other versions the long number in middle is different such as:-
#define LCD_328348_PORT portb
#define LCD_1835698_PORT portb
What is the significance of this number? Why does it vary maybe every time I compile and do I need to worry about it changing?
Re: LCD code
This is just a method we used here to allow multiple LCDs to be added to a program without causing problems. The number is random and you do not have to worry about it changing.
