Floating point.
JAW
Been thanked: 4 times
Floating point.
Post by JAW »
Hi All,
Is their any way that a floating point can be saved to the eeprom eBlocks module? I have tried floattostring and then taking each single character of the sting and converting it into a byte. This works fine for the numbers but I get stuck with the decimal place. Any ideas?
James
Re: Floating point.
Hello James
How are you converting the string into a byte, Can you not simply write the bytes of the string directly to the EEPROM.
E.g.
String Manipulation:  string_var = FloatToString( Float_Var )
String Manipulation:  string_length = length ( string_var )
Calculation: IDX = 0
While: IDX < string_length
Component Macro: EEPROM Write: IDX, string_var[IDX]
Calculation: IDX = IDX + 1
Maybe you could store the string_length byte as the first byte of the EEPROM so you know how many bytes to read back to rebuild the string.
E.g.
Component Macro: EEPROM Write: 0, string_length
Calculation: IDX = 1
While: IDX < ( string_length + 1 )
JAW
Re: Floating point.
Post by JAW »
Thanks for that I didn't realise you could do some of the suggestions you made. How would you reassemble the data in the eeprom to a floating point ? I've attached my test file so far if anyone else wants to make use of it.
Many Thanks
James
Save String.fcf
Test File
(7.5 KiB) Downloaded 479 times
Has thanked: 114 times
Been thanked: 422 times
Re: Floating point.
Post by Steve »
A neater way would be to use the code-customization feature of the component and write C-code functions that save and retrieve a float directly. A floating point number is stored in 4 bytes, and there will be a way of directly saving these 4 bytes to EEPROM by directly accessing the memory used to store the number in the chip's RAM.
JAW
Re: Floating point.
Post by JAW »
Hi Steve,
I have not used C for a long time. Could it be done with Flowcode components ? Or could you maybe point me in the right direction of writing a custom component in C?
Many Thanks
James
Re: Floating point.
Post by Steve »
The C code is something like this (assumes you have a Flowcode float variable called MyFloatVar):
unsigned char* pMem;
unsigned char float_array[4];
pMem = (unsigned char*)&FCV_MYFLOATVAR;
float_array[0] = *pMem;
pMem++;
float_array[1] = *pMem;
pMem++;
float_array[2] = *pMem;
pMem++;
float_array[3] = *pMem;
//TODO: save float_array to EEPROM
The 4 bytes in the "float_array" variable could then be saved to EEPROM. To work backwards, do the opposite:
//TODO: populate float_array from EEPROM
*pMem = float_array[0];
pMem++;
*pMem = float_array[1];
pMem++;
*pMem = float_array[2];
pMem++;
*pMem = float_array[3];
NOTE: I've not tried this, but it might work! And also, there may be better ways of doing this.
JAW
Re: Floating point.
Post by JAW »
I can't get the code to work. I would really appreciate some help. The code compiled, I loaded it into the pic and no joy.
James
PS I don't know if it's worth starting another thread but I'm also keen on getting the displayed floating numbers down to 2 decimal places.
Seem to be a bit obsessed with floating points at the moment !!!!
C Code eprom.fcf
(7.5 KiB) Downloaded 474 times
Re: Floating point.
Post by Steve »
The code I gave you is not complete and is an example only. Once you have converted the float to the 4-character array, you can save this to the EEPROM. Later in your code, you can retrieve these values from EEPROM and then recreate the float value.
Look at my "TODO" statements in the code.
GTF
Has thanked: 20 times
Been thanked: 52 times
Re: Floating point.
Post by GTF »
I know this is an old thread but what about something like this example for those of us who are code challenged.
Grant
Float to EEPROM_Test.fcf
(10 KiB) Downloaded 377 times
