12F683 chip crashes
JWalthall
Been thanked: 1 time
12F683 chip crashes
Post by JWalthall »
I have a problem when I choose a 12F683 chip my Flowcode crashes. Is this a corrupt fcf file ? If so where can I get a new 12F683 .fcf to replace my corrupt one. also can I just delete and paste the new file in the directory?
Thanks,
J Walthall
Re: 12F683 chip crashes
Here is my 12F683.fcd.
My V3 runs ok with it.
Just overwrite original.
With Vista you may need Admin rights, but not 100% sure, since I have always been admin for my pc’s
12F683.fcd
(5.02 KiB) Downloaded 320 times
If the chip is crashing then it could be that the chip is becoming lost or the watchdog is enabled.
Most of the 16F pic micro devices have a stack of 8. This means you can have up to 8 macro calls away from your main program. Some of the macro calls can be hidden away in component C code.
You can enable the BoostC software stack to test if it is this causing your problem. Details on this are available in the BoostC manual located inside the Flowcode V3/BoostC folder.
If the watchdog is enabled then you can disable this via the chip configuration window.
Ben, I did not think setting watchdog, or stack greater than 8 would cause the actual flowcode program to crash . Agreed those things you mentioned would cause the hardware to malfunction, not the flowcode software. Isn't that the issue i.e
JWalthall wrote: have a problem when I choose a 12F683 chip my Flowcode crashes
or have I miss read?
Sorry I think I miss read. Ok Your Flowcode should not be crashing watchdog or stack aside.
Are you using V3 or V4 of Flowcode.
Here is the up to date V3 FCD.
12F683.fcd
(5.02 KiB) Downloaded 314 times
