Using of Scrolldisplay command
kilopondio
Post by kilopondio »
Hi fellows!.
I wanted to know if someone has some single sample to use the Scrolldisplay command.
The help mentions that it has 2 arguments but it`s no t very clear so please help me in this stuff.
Thank you and have a nice week!,
Kilo
Re: Using of Scrolldisplay command
If you use this format s,p (except you use just numbers)
Then s= shift direction: 1 is shift right, 0 is Shift left.
p = places
so if you have a string "Hello" that will start at 0,0
Note[ = left edge of display
then if enter in scroll box 1,3 then instead of [Hello it will display [ Hello
or if you enter 0,3 in box then instead of [Hello it will display [lo since shift 3 places to left.
Hope I have made it clear enough. If not I will post a screen shot.
BTW I thought scroll display was in V4 only?
kilopondio
Dear buddy,yes you were right, the scrolldisplay command was in FLOWCODE 4 but sorry I didn`t understand very well your explanation.
Please give some real single sample because I didn`t see no sample about this command.
Thank you and sorry for inconviniences!
Kilo
Here is an example. To understand better, watch direction variable and at the same watch LCD.
Then change places variable form 1 to 2 and watch display.
You should notice there are two variables required in the LCD scroll component.
1st variable is to scroll left or right : 0=scroll left 1=scroll right.
2nd variable is number of places to scroll. 1 = one place , 2 = two places, 3 = three places etc.
Scroll.fcf
(6 KiB) Downloaded 556 times
