Tutorail 34 bugs ?
Forum for problems or queries regarding the Flowcode application and compiler usage.
canielsen
Tutorail 34 bugs ?
Post by canielsen »
Hi.
IΒ΄m newbie and trying to learn to use flowcode. (Version 3 pro purchased from ELEKTOR).
IΒ΄m a littel bit confused, by some of the tutorials, cause the simulation does not work as expected.
Example: When iΒ΄m trying to run tutorial 34 (TUT_34), the display show 37+21 = 0 and 37 - 21 = 0 - when i run the simulation.
If i make the circuit with e-bloks, and program the microcontroller, the programs works ok and the display shows the right information.
Why does some of the tutorials not works properly when the programs are simulated ?. Am i doing somethinh wrong ?.
Re: Tutorail 34 bugs ?
Tutorial 34 is a C code demo to demostrate how to use C code in your programs.
The simulation does not work because Flowcode cannot simulate raw C code.
canielsen
Post by canielsen »
Thank you very much.
