I'm programming the temperature & humidity sensor SHT15 using fv4,
I've connected the temperature sensor in SPI Interface, to initaite transmission ,i need to set the DATA LINE as LOW & the SCK as HIGH
followed by an Low pulse on SCK,and raising DATA again while SCk is maintained HIGH ...How to set the lines like this..?
Temperarure Sensor SHT15
Re: Temperarure Sensor SHT15
You should be able to set up this comms functionality using the properties of the SPI component.
