Zigbee and Baudrate
Mathy
Has thanked: 30 times
Been thanked: 33 times
Zigbee and Baudrate
Post by Mathy »
Hi !
I'm trying Xbee from maxtream with the lastest Flowcode release.
How can I set the baudrate ?
I had a look into your C code component and I think the macro only configure the Xbee module in 9600 bauds with a 19660800 crystal
That's right ?
Thank you :)
Mathy
Re: Zigbee and Baudrate
Hello Mathy
The Zigbee component automatically sets up the baud rate for you at 9600 based on your crystal speed. You just have to connect the XBEE module to the microcontroller UART via a voltage level shifter if you are using a 5V system.
