After I program a 12F609 on my eb006 board I'm not able to reprogram the chip anymore. How can this be solved.
I programmed with the configuration shown in the attachment
When i try to reprogramm I get the error shown in the attachment
I can reprogram the chip in my stand alone programmer with no problems.
Problem programming 12f609
- config.jpg (89.66 KiB) Viewed 3054 times
- error.jpg (14.62 KiB) Viewed 3054 times
Re: Problem programming 12f609
And even a program this simple will not work.
- Flowcode1.fcf
- (5.5 KiB) Downloaded 243 times
I had the same error message appear with one of my microcontrollers. The only way I stopped the message, was to replace microcontroller with another one.
You said you can program with a standalone programmer, does it also verify 100%, or is verification not done?
If chip is faulty, then prog won't run.
looking at your flowcode, I did notice, you have target osc set for 4MHz, but your osc in configuration menu is set for 8MHz.
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
I've also noticed that under certain circumstances, these low pin-count chips will reprogram only when the XT/RC switch on the EB006 board is set to one of the positions. I can't remember which one, so you might want to try reprogramming with differing switch positions.
