Frank123
Posts: 36 Joined: Fri Jan 15, 2010 5:17 pm
Has thanked: 1 time
Post
by Frank123 » Thu May 13, 2010 5:09 pm
I recently use Flowcode V4 and therefore I get .fcf Flowcode of V3.
Unable to run RXINT. I do a lot of change in the .fcd but the only one that works is to resume my old version (find on this forum) :
[USART_RX]
Name="Réception USART"
UseExplicitHandlerCode=1
FlagReg=
FlagBit=
HandlerCode="if (pir1 & (1 << RCIF))\n{\n FCM_%n(); // call selected macro\n}\n"
UseExplicitEnableCode=1
EnReg=
EnBit=
EnableCode="intcon.PEIE = 1; // Enable peripheral interrupts\nintcon.GIE = 1; // Enable global interrupts\npie1.RCIE = 1; // Enable USART receive interrupts\nrcsta.CREN=1; // Enable reception\n"
DisableCode="pie1.RCIE = 0; // Disable USART receive interrupts\n"
OptCnt=0
TmrOpt=0
Frank
Electronics teacher
Posts: 3434 Joined: Tue Jan 03, 2006 3:59 pm
Has thanked: 114 times
Been thanked: 422 times
Post
by Steve » Fri May 14, 2010 7:18 am
Please post your current V4 FCD file and the old V3 FCD file (with your modifications) and we'll try to create a new V4 one for you.
Frank123
Has thanked: 1 time
Post
by Frank123 » Fri May 14, 2010 8:38 am
V3 FCD File
18F4331.fcd
PIC18F4331 V3 (12.46 KiB) Downloaded 328 times
V4 FCD File
18F4331.fcd
PIC18F4331 V4 (8.48 KiB) Downloaded 352 times
Only USART_RX (add by me) is ok on this.
Frank
Electronics teacher
Post
by Steve » Fri May 14, 2010 4:23 pm
You might want to try the st_bit() and cr_bit() functions instead of using the "dot" notation.
Do you get specific error messages when compiling, or is the program compiling ok but not working as expected?
Frank123
Has thanked: 1 time
Post
by Frank123 » Fri May 14, 2010 4:35 pm
the program compiling ok but not working as expected with "RXINT" and it's working well with "Réception USART".
Is't possible to me to change in c code and recompil directly ? How to ?
Frank
Frank
Electronics teacher
Post
by Steve » Mon May 17, 2010 7:20 am
Hi Frank,
Aaah, I see the problem now - sorry I was slow on the uptake.
It looks like the EnableCode entry of the RXINT function might need to change from this:
EnableCode="st_bit(pie1, RCIE);\n"
...to this...
EnableCode="st_bit(intcon, PEIE);\nst_bit(pie1, RCIE);\n"
Frank123
Has thanked: 1 time
Post
by Frank123 » Mon May 17, 2010 3:07 pm
Non ça ne marche pas. C'est la première chose que j'ai essayé.
Frank
Electronics teacher
Posts: 15312 Joined: Mon Oct 16, 2006 10:48 am
Has thanked: 4803 times
Been thanked: 4314 times
Post
by Benj » Mon May 17, 2010 4:04 pm
The RXINT interrupt allows for incoming data to interrupt the program so you can pull it from the incoming UART buffer and process it straight away ready for the next incoming byte.
When the PIC device starts up it enables the UART interface but the receive function is switched off.
Calling the ReceiveByte macro at the start of your program before enabling the interrupt will enable the receive function and your interrupts should work from then on.
Frank123
Has thanked: 1 time
Post
by Frank123 » Wed May 19, 2010 8:54 am
thank you Ben,
it works with it.
I do not understand why one RS232Send is needed before initializing the interrupt but I would look at the C.
Frank
Frank
Electronics teacher
