I have a problem with the AD conversion. I work with a 18F4331. I made a little macro that occurs every 200μS. It should generate a square wave of period 2 ms with a duty cycle of 80%.
In addition to 1.8 ms I measure 2 channel with AD converter.
If I put the measure to follow I obtain a term which does not correspond to what I'm waiting.
By cons, if I do my interval measures 200μS it works.
Can you tell me why or fix this bug.
Frank
2 Conversion AD
Re: 2 Conversion AD
Hi Frank,
Sorry I may be being a bit thick here, (its monday morning after all) but is the problem that the delays are not coming out ok? or that the analogue readings are incorrect?
I think its this sentance that is throwing me off.
If you could please state your problem again then hopefully I will be able to help you solve the problem.If I put the measure to follow I obtain a term which does not correspond to what I'm waiting.
Frank123
- Has thanked: 1 time
Re: 2 Conversion AD
Hi Benj,
English language is not always easy and i use, sometimes, automatique translation
It's the delay that is not ok. I want a 2 ms period (like second example with just on conversion) but i have 35.52 ms (like first example) if i make two successivex conversions.
The result of ADC it's ok.
Frank
Frank
Frank
Electronics teacher
Electronics teacher
- Steve
- Has thanked: 114 times
- Been thanked: 422 times
Re: 2 Conversion AD
Hi Frank,
We have many French users, and if you prefer you can post in French (or any other language) instead of English - or perhaps post in French and include a translation into English as well. We can always use the online translators anyway.
- Dan81
- Been thanked: 60 times
Re: 2 Conversion AD
Salut Frank
As tu résolu ton problème ?
il semblerait que la durée des 2 acquisitions soient supérieures aux 200us de ta base de temps. Surprenant !
Envoie moi ton prog si tu veux.
Daniel
Daniel
- Steve
Re: 2 Conversion AD
The "Lire comme Octet" ("read as byte") ADC macro does take a certain amount of time, so your 200us interrupt is probably not firing properly.
In your "=9" branch, you could put some additional debugging statements (such as i/o transitions) around and between the ADC macro calls to determine how long each is taking.
