Flowcode 4 / Miac compile error
petesmart
Has thanked: 187 times
Been thanked: 140 times
Post by petesmart »
Hi Support team,
I have been playing around with the MIAC device and have attempted to create multi-layer menus for display of application and diagnostic data using Flowcode 4 professional. The programme works fine in simulation mode and fucntions as you would expect using the up/down, left/right combination keys.
When I go to compile flowcode to hex or chip i get the following failure
multilevel_menu3.c
Starting preprocessor: C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\pp.exe "E:\My Documents\HAZTECH SYSTEMS\matrixmultimedia\software_component_library\menus\multilevel_menu3.c" -i C:\PROGRA~1\MATRIX~1\FLOWCO~2\BoostC\include -d _PIC18F4455 -la -c2 -o "E:\My Documents\HAZTECH SYSTEMS\matrixmultimedia\software_component_library\menus\multilevel_menu3.pp" -v -d _BOOSTC -d _PIC18
E:\My Documents\HAZTECH SYSTEMS\matrixmultimedia\software_component_library\menus\multilevel_menu3.c(872): error: missing right paren
E:\My Documents\HAZTECH SYSTEMS\matrixmultimedia\software_component_library\menus\multilevel_menu3.c(872): error: error in 'if' expression
E:\My Documents\HAZTECH SYSTEMS\matrixmultimedia\software_component_library\menus\multilevel_menu3.c(872): error: missing semicolon
E:\My Documents\HAZTECH SYSTEMS\matrixmultimedia\software_component_library\menus\multilevel_menu3.c(864): error: failure
failure
Return code = 1
Flowcode was unable to compile the flowchart's C code due to the following errors:
If your flowchart contains C code, please review this carefully. If your flowchart contains no C-code or you have thoroughly reviewed the code, contact Technical Support.
FINISHED
I have attached the the various files .fcf, .c and the error log for your review. I have looked at the 'C' file and it looks ok, however i would appreciate if you could take a look and verify for me pls. Th erros dont make a lot of sense to me is the (XXX) the line no?
Not having much experince with nested loops - I am suspecting that with the amount of tests that I'm requesting that my loops maybe too deep... is there a maximum no and depth?
would appreciate any assistance that you may provide.
all the best
Pete
multilevel_menu3.c
(26.37 KiB) Downloaded 489 times
multilevel_menu3.msg.txt
(2.1 KiB) Downloaded 478 times
multilevel_menu3.fcf
(34.84 KiB) Downloaded 464 times
sorry about that Chief!
Re: Flowcode 4 / Miac compile error
Hello Pete,
Yes the XXX is the problematic line number in the C code.
Looking at the C code this line is the problem.
if (FCV_PAGE_V_PLANE < == 1)
Going to the icon in Flowcode inside the page_Up macro.
page_V_plane < = 1
Removing the space will allow compilation to happen correctly.
page_V_plane <= 1
petesmart
Post by petesmart »
Thanks for the fast response Ben, much appreciated.
I checked the other plane of the menu structure page_H_plane <= 0 and had made a similar mistake with the space < = ..
deleted the space from both examples and it compiled with no errors...
Interesting point - under simulation from within Flowcode it run ok and functioned as expected, complete with spaces in both places. Not sure if this is a bug or a trap for young players :?:
Again thanks for your assistance
all the best
Pete
