Further to my previous, in addition to the problem covered by that, I now find I am unable to save new programs and the message as follows when attempting to do so.
___________________________________________________________________
Access to F:\***.fcf was denied
_______________________________________________________________________
Any suggestions??
Unable to save newly created **.fcf
Re: Unable to save newly created **.fcf
I only have an issue like that if saving/compiling onto a root of a flash stick. Reason for that is you can only have a certain number if individual files on the root. Any more you will get issues compiling. If you create one new Flowcode, then several files will be saved after compliling
I’m not saying that’s the issue in your case but could be?
But it is something to be made aware of.
Try moving files that's on a root directory into a folder.
You are correct, that is exactly what was happening.
many thanks
many thanks
Your welcome.
Glad, you are sorted and thank you for letting us know.
