Serious Warning
Ron
Has thanked: 2 times
Serious Warning
Post by Ron »
How do I determine where this warning is coming from. I searched the "C" file using VS2008 and only found 4 lines in the code that call out FCM_TMR0. How do I locate which is causing this and where it is located in my project?
Building CASM file
Serious Warning: Possible sw stack corruption, function 'FCM_TMR0' called by more than one asynchronous thread (main/Task, interrupt, interrupt low)
The 4 areas I have found the FCM_TMR0 are listed below.
First Area Of C file
//Macro function declarations
void FCM_TMR0(); // This is required.
Second Area Of C file
//Call Macro: TMR0
FCM_TMR0(); // I think this is where I enable TMR0 in flowchart
Third Area Of C file
void FCM_TMR0()
//Comment: // This is the TMR0 code itself
Fourth Area Of C file
void interrupt(void)
if (intcon & (1 << TMR0IF))
FCM_TMR0();
clear_bit(intcon, TMR0IF);
Thank you,
Ron
Re: Serious Warning
Hello Ron,
Its hard to see without having your program but are you calling the TMR0 macro via a software macro icon or is it simply the interrupt icon that referrs to it.
If you are using a software macro call then this should not be needed as the timer macro will run by itself once you have called the interrrupt enable function.
