EB006 MULTI PROGAAMMER
stevel
Post by stevel »
When i have sent hex file to chip and try to send again i get window up saying usb cable not connected and the cable is connected. i have to shut down flow code and reboot every time i want to send hex file to the chip i can only send hex file once and after that its allways saying usb not connected.
Re: EB006 MULTI PROGAAMMER
Are you running multiple instances of the PPP software? This could probably be enough to cause the problems you are describing.
