Can Bus message id problem
Zane
- Flowcode v5 User
- Has thanked: 93 times
- Been thanked: 76 times
I have found that when setting a message id in the canbus module by using the macro SetTxId that when it is received by another node (the node is set to accept all messages) that the lsb of the message id is stripped and cannot be seen by the node receiving the data ie a message id that is odd cannot be seen. If you set the message id via the external properties box and then send the data any message id is received correctly. Any help with this would be great.
Zane
Zane
Re: Can Bus message id problem
Hello Zane,
If you look in the CAN component help file then you will see that the ID value is shifted 5 places to the right.
eg for ID 1
IDlow = 0b00100000 / 0x20 / 32
IDhigh = 0b00000000 / 0x00 / 0
The easiest way to calculate this is to put your required ID into an INT variable and then do the following to split the INT into a low and hi byte.
INTvar = IDvalue eg 1
IDlow = INTvar << 5
IDhigh = INTvar >> 3
To recombine into a single ID variable on the receive side you would have to do the following.
INTvar = IDhigh << 3
INTvar = INTvar | (IDlow >> 5)
Hope this helps.
eg for ID 1
IDlow = INTvar << 5
Hope this helps.
Zane
- Flowcode v5 User
Yes i have already done this taking the message id and applying the given algorithm. If i set a message id via the macro and it is say 2 and then it is converted via the algorithm, the receiving node when reading the message id value after its is converted back again is also 2. If i have a message id of say 3 the recieving node will will see it as 2. If i have a message id of 7 the recieving node will see it as 6.
As i mentioned in my last post if you set the message id via the external properties box, the message id that is set is recieved corectly by the recieving node. The issue is only relates to the SetTxId macro.
Thanks for your help.
Zane
Zane
Hello Zane,
Are you sure you have your calculations correct. It sounds like the least significant bit is being left off.
Eg.
ID 2 in binary is 0b00000010 you are receiving 0x00000010
ID 3 in binary is 0b00000011 you are receiving 0x00000010
ID 7 in binary is 0b00000111 you are receiving 0x00000110
As you say the receiver is working correctly when it is passed a ID from the external properties so this makes me think that the error is in the transmit ID calculation before you pass the SetTxID macro the ID values.
Maybe you could attach your program and I'll see if I can spot anything untoward.
Eg.
Zane
- Flowcode v5 User
I have two basic programs, A transmits data from buffer 0, the message id is set via variable C and data is set from variables A and B.
Program B recieves data from buffer 0 and and places the transmitted data in variables A and B and the message id is calculated and placed in the variable ID. See how you go with this but every time i try and send a message with an odd ID the lsb is stripped so the id comes out even.
After this if the message id is set in the external properties box in program A, in program B when the message id is read and calculated back out again and placed in the variable ID, the message id is correct.
Once again thanks for your help.
Zane
Zane
Hello Zane,
Your flowcharts looked like they should have worked. I spotted that your ID variables was still down as a byte in bioth programs so I have changed this and I have also slightly changed the technique to create the ID variable.
Let me know how you get on using these versions of the programs.
Hi Zane,
Thats very odd. How are you showing the ID at the receiver end? If your lighting LEDs could it be that pin 0 has been damaged and is not lighting the LED?
What chip are you using? Are you using the internal or external CAN driver?
Zane
- Flowcode v5 User
I am using no hardware at the moment, just using the two instances of flowcode running the two programs using flowserver as the interface between the two and viewing the variables on screen.
I have attached 3 programs, SendIdProperties which sets the message ID via the properties box and is set to 17. When ruuning this in conjunction with the receive program, when pausing the receive program the message ID shows up as 17 (variable "id"). The other program SendIdMacro sets the message ID via the macro. When running this with the receive program, this time the message ID shows itself as 16 (variable "id").
I have tried all sorts of things but no matter what i do when setting the message ID via a macro the LSB is always stripped. Thanks for patience with this.
Kind Regards
Zane
Kind Regards
Zane
- SendIdMacro.fcf
- (7.5 KiB) Downloaded 624 times
- SendIdProperties.fcf
- (7 KiB) Downloaded 585 times
- Receive.fcf
- (7.5 KiB) Downloaded 582 times
Hi Zane,
Right now I see that the problem lies somewhere in the simulation. The program should work correctly on the hardware. I will see if I can track down the bug in the Vnet communications.
Zane
- Flowcode v5 User
Thanks for your work with this. I have not tried with any hardware yet, just in the process of making some boards for myself so should be able to try sometime this week. I will let you know how we go.
Kind Regards
Zane
Kind Regards
Zane
Zane
- Flowcode v5 User
I have completed some circuit boards and have set message ID's to odd and even values and everything works fine.
Zane
Zane
Hi Zane,
Thats great many thanks for letting me know.
Hopefully we can get the simulation problem nailed down and fixed.
